Fiesta-Si.com • View topic - Gearbox Mountings
 Post subject: Gearbox Mountings
PostPosted: Wed May 17, 2006 9:45 pm
A few weeks back I posted a topic in the "Parts Wanted" section about these
Jd said that the mounts that are just simple things and only cost a few quid each. I work in a Motor Factors and our catalogue's list them upto around 1993, but none afterwards.
Been upto 2 Ford dealerships and they both told me that they're no longer available :( A Mechanic I asked to look at the mounts is also adamant that they're a different type to the normal ones, they have some sort of shim either side he said.
So as you can imagine im a bit consfused. Will the older type fit or not? Just a rectangular piece of rubber with a thread at the top and bottom?
MallardSi seems to be having a similar problem looking at his post, and to make matters worse, according to him the front and rear ones are different! Argh!
Can anyone help?
Chris
PostPosted: Wed May 17, 2006 10:15 pm
Yeh they do, the zetec and diesel mounts are different to HCS and CVH ones, like diesel driveshafts are hollow on MK3 Fiestas :shock:
Shite though, i fitted the standard mount which were about a fiver a piece and they dont fit on the back mount, you need the bigger ones with the metal shims either side like you said and they are about 15 - 20 a piece :| :x
PostPosted: Thu May 18, 2006 8:06 am
PostPosted: Thu May 18, 2006 9:06 am
PostPosted: Thu May 18, 2006 11:01 pm
Cheers Guys :)
