Fiesta-Si.com • View topic - Cutting out when dropping the clutch?
PostPosted: Mon May 08, 2006 11:33 pm
PostPosted: Tue May 09, 2006 12:10 am
PostPosted: Tue May 09, 2006 1:42 am
PostPosted: Tue May 09, 2006 4:05 pm
Ive got a 2.0 one ive attempted to fit, raced some shitbox fiesta earlier and that was a 2.0 an all, he said you need to use the ISCV from the car you got the MAF and ECU from, well thats long gone bye byes ! :lol:
PostPosted: Tue May 09, 2006 6:49 pm
so a 2L iscv rather than a 1.6 version
PostPosted: Tue May 09, 2006 10:50 pm
Indeed and he said get a 2.0 lamba aswell, mind you since ive fitted the cat back on ive been getting between 80 - 100 miles out of 20.00 of normal unleaded which is better than what it used to do which was around 55 - 65 ish :rolleyes:
PostPosted: Wed May 10, 2006 12:56 am
PostPosted: Wed May 10, 2006 11:18 pm
iscv or have u got a aftermarket chip on in if so take it out n c if that works, whats it like going up in the engine revs when ur trundeling along?
PostPosted: Thu May 11, 2006 1:05 am
It picks up fine when im going, but at standstill its really slow at revving up, it used to rev up and redline really fast when i first put the 2.0 in in february. ISCV is an RS1800 item.
PostPosted: Thu May 11, 2006 8:57 am
have you checkecked hoses for air leak?
PostPosted: Fri May 12, 2006 1:53 am
PostPosted: Fri May 12, 2006 10:57 am
PostPosted: Fri May 12, 2006 7:48 pm
aye, gearbox or clutch when the revs dont pick up with speed equally,
out of interest:
hows best to get the iscv off an si inlet manifold? seems a bit of a cunt to get to the bottom screw/bolt?
or do you remove the bit it houses into aswell??
PostPosted: Sat May 13, 2006 12:46 pm
Its just 2 screws paul, think you have to use a stubby screwdriver. :)
PostPosted: Sun May 14, 2006 3:29 pm
yeah i know its two screws but fooked if my hands can get into that tight gap.. (talking about the car.)
will have to get mi mirror out onto it
PostPosted: Sun May 14, 2006 10:38 pm
PostPosted: Sun May 21, 2006 9:55 pm
PostPosted: Mon May 22, 2006 12:16 am
