Fiesta-Si.com • View topic - Fuel pump relay - which one?
It is currently Mon Mar 23, 2026 5:16 pm
PostPosted: Tue Jun 26, 2012 12:58 pm
As per title, which relay is the fuel pump one?
Thanks.
PostPosted: Tue Jun 26, 2012 1:00 pm
#5 Rolebama
View Profile View Forum Posts Private Message
Formula 1 Driver
I would check the fuel pump relay. It should be the second from the right at the front in fuse/relay box next to battery.
PostPosted: Tue Jun 26, 2012 1:04 pm
Buttttt the si doesn't have a fuse box in the engine bay lol. It's all under the dash
PostPosted: Tue Jun 26, 2012 1:12 pm
ah fail - i just typed fiesta fuel pump relay into google :lol:
one sec!
PostPosted: Tue Jun 26, 2012 1:24 pm
Every forum says different on the searches.
So gay! I might just leave my car here in the car park to rot away lol
PostPosted: Tue Jun 26, 2012 1:33 pm
Must be the pump or wiring. Swapped the relay and put it in the fog light relay hole and it clicked. So the relay is ok. Fml.
PostPosted: Tue Jun 26, 2012 1:50 pm
Sounds like the pump has failed then :(
PostPosted: Tue Jun 26, 2012 1:58 pm
hard job?
PostPosted: Tue Jun 26, 2012 3:29 pm
Not sure, never done it before because I've never had the need. Apparently not too hard from what Phil said.
I'll probably crack on with that tonight, maybe.
Gives me an exhaust to paint the tank and under seal all the underside of the floor above the tank though :lol:
PostPosted: Tue Jun 26, 2012 3:42 pm
I lowered the petrol tank on my exes escort to do the brake lines as they run above the tank, and it was an easy enough job. You'll be fine
PostPosted: Tue Jun 26, 2012 6:38 pm
When my fuel pump died a death on the 106, the fuses also blew.
PostPosted: Tue Jun 26, 2012 6:47 pm
That sucks. I've given up. Fords SHITTY design meaning stuff breaks when you undo it due to rust and whatever has annoyed me.
Why put two stupid rectangular nut things in places where one of them you can hardly get to expecting it to stay in place with I presume a couple of shitty tack welds.. WD40'd them up for the night. Tomorrow I'll crack on and get annoyed with them some more.
Prepare yourself for a few days of ford hating from me :lol:
PostPosted: Tue Jun 26, 2012 6:49 pm
Are the fuel pumps not easy access under the rear seats like with Peugeot's or Honda's? :S
PostPosted: Tue Jun 26, 2012 7:19 pm
Nope! You have to drop the tank to get to them. Completely shit design if you ask me! They should have just made an access panel or something rather than piss around with stupid ideas to cost people time and money.
PostPosted: Tue Jun 26, 2012 11:19 pm
This is what I always find with Fords - stupid designs that just annoy the fuckmout of me when working on them!!
PostPosted: Wed Jun 27, 2012 8:25 am
rob's old xr2i - someone got pissed off like you and made their own access flap :lol:
PostPosted: Wed Jun 27, 2012 8:29 am
Silly Ford!
