Fiesta-Si.com • View topic - 1991 Fiesta 1.6s Ignition Module where to find one
PostPosted: Wed Jun 20, 2012 9:07 pm
distributorless ignition system 1600cvh
module has a 12 pin right angle plastic block connector and an alloy casing.
My Fiesta project car has lost its spark the car was going great two weeks beforehand at an autotest now there is no spark whatsoever , it has new plugs, leads and coil pack and there is 12v going to centre terminal of coil pack plug. I have cleaned crankshaft position sensor also.
Ordered a module from motor factor cheapest one was £120 ! Part system said part was correct for vehicle but block connector was slightly different and module was smaller , part company technician then said its only available from ford.
Ford quoted around £ 350 for the part which needs to be payed upfront :(
does anyone have a similar part for a cvh 1600 or know of anywhere that stocks older ignition parts?
much appreciated
Alastair
PostPosted: Wed Jun 20, 2012 9:54 pm
Have you got a picture of the part you are after?
Also, it might be worth putting a post on fiestaturbo.com :)
