Fiesta-Si.com • View topic - Gauges and Fittings
It is currently Mon Mar 23, 2026 8:32 pm
 Post subject: Gauges and Fittings
PostPosted: Tue Mar 14, 2006 11:53 am
I am in the process of buying some gauges for the Xr and as the car is having the full engine out rebuild i thought it would be good idea to fit them now,
but i am unsure on where they are ment to fit to the engine to take the readings!
The gauges are Volt Meter, Oil Pressure and Oil Temp
the engine is 1.6 Efi Cvh
Many Thanks
Tiller
PostPosted: Tue Mar 14, 2006 3:06 pm
Oil Temp comes from the bottom of the sump.
Oil pressure just goes in one of the oil lines.
Voltmeter...Don't see the point in this gauge, but depends what you want to measure the voltage over.
I wish I had oil pressure on mine :(
