Fiesta-Si.com • View topic - front wheels rubbing
It is currently Mon Mar 23, 2026 5:16 pm
 Post subject: front wheels rubbing
PostPosted: Sat Apr 14, 2012 6:26 pm
on my fiesta i have escort 7spokes and when i full lock it to the left the wheels rub on the inner arches does any one else have a problem with wheels rubbing on the front
blunty
 Post subject: Re: front wheels rubbing
PostPosted: Sat Apr 14, 2012 7:12 pm
Sounds like your tracking might need looking at if only one wheel is rubbing
PostPosted: Sun Apr 15, 2012 4:27 am
Are they 17s? on a mk3?
If so they are too big and they will rub no matter what really. its only the plastic arch liner though so not too much to worry about. even 16s might give it a little bit of a scrub here and there.
PostPosted: Sun Apr 15, 2012 9:17 am
What inch wheel and tyre size you have? 15" 195/45 is a good fit to avoid rubbing.
PostPosted: Sun Apr 15, 2012 9:58 am
i have 15s with 195/45 15s on them iv had the steering rack centralised and the tracking done. the garage that done its said its all straight and it still rubs of the inner arches and they told me it because the wheels are of an escort and not a fiesta
blunty
PostPosted: Sun Apr 15, 2012 10:04 am
That's strange, I have escort gti's on mind with 195/45 and its fine. Try spacing the wheels out abit, maybe 3mm or sumat.
PostPosted: Sun Apr 15, 2012 11:23 am
Yeah it may be to do with the offset, different ford wheels sometimes have slightly different offset due to what car they are designed for.
Spacers are your answer, nothing too big, 2-3mm should cure it.
To get an idea of what size spacers you need if you don't have immediate access to some, just get some thin washers and place them over the studs until it cures the problem then measure how thick the washers are in total. But also, make sure its not so thick that it rubs on the outer arches when going over bumps.
Also, don't drive mega far with washers behind the wheel, its not suitable.
ORRRRRRRRRR. Just don't go full lock :D
PostPosted: Sun Apr 15, 2012 1:41 pm
Fiesta wheel offset is ET41. I had mondeo wheels for a while that were ET47 had the same problem check the offset 2 or 3mm spacer will be fine for ET45. 47 will need 5mm spacer. Make sure if u use spacers that the centre bore of the wheel locates on the hub properly if it don't u need to get hubcentric spacers mine cost 60 for a pair and are for a focus
THE DON..... DON DIGGLER
PostPosted: Sun Apr 15, 2012 3:19 pm
the 7spokes are 6j with an et40 iv tried spacers of a mate and it needs 8mm spacers to clear the arch also haveing the car back from the garage it pulls to the left when driving and they said its all straight :frown:
blunty
PostPosted: Sun Apr 15, 2012 6:46 pm
I have this on my car ATM, I set my tracking by eye as I was in a rush, it's because the front wheels are square with each other but they are not square with the rear wheels, you'll need to get 4 wheel laser alignment done, this cured my car after I fitted new shocks and wishbones
PostPosted: Sun Apr 15, 2012 10:20 pm
8mm spacers?? That cant be right!
PostPosted: Sun Apr 15, 2012 11:48 pm
Could be, depends on the offset really.
PostPosted: Mon Apr 16, 2012 8:57 am
the 8mm is only on the drivers side at the moment i havent tried the passangers side as i thought 8mm was a bit much
blunty
PostPosted: Mon Apr 16, 2012 10:36 am
Well, if 8mm is needed on one side and not the other, something is seriously wrong with your car or the wheels.
PostPosted: Mon Apr 16, 2012 11:03 am
I don't see where it says one side I thought it was both
PostPosted: Mon Apr 16, 2012 11:44 am
Bent chassis??? has it been in an accident before you bought it?? check all your wheels are the same offset as some wheels designs were made with different offsets, you might want to find a body shop with a jig make sure the cars all straight
PostPosted: Mon Apr 16, 2012 5:25 pm
after taking it back to the garage they rechecked the tracking and found it was out quiet a bit so they had to redo it and know it only needs 5mm spacer at the most on both sides could even be less as it only just touching on full lock after they retracked it :lol:
blunty
PostPosted: Mon Apr 16, 2012 5:27 pm
PostPosted: Mon Apr 16, 2012 5:47 pm
Thought it would be the tracking, like I originally said lol.
I wouldnt worry about spacers if its only just touching :)
PostPosted: Thu May 03, 2012 12:57 pm
i hac it with mine m8 sop i put 3mm spacers on and it cured it
