Fiesta-Si.com • View topic - engine mounts zetec
 Post subject: engine mounts zetec
PostPosted: Wed Mar 07, 2012 10:29 pm
I need both mounts for my 2.0l silvertop mondeo engine. Anyone selling any? In terms of were i need to drill in the bay (as i have a 1.4) can sumone post a pic?
Ta, ben
 Post subject: Re: engine mounts zetec
PostPosted: Wed Mar 07, 2012 11:35 pm
ive got a front one
PostPosted: Thu Mar 08, 2012 1:11 am
Shouldn't need to drill anything, all the mk3.5s and most mk3s have the neccessary mounting points you need, as for the mounts tho, you would be fine with just the rear mount
PostPosted: Sat Mar 10, 2012 11:08 pm
how much p+p big g?
tonwah, does it have to be zetec yeah?
i think i might, havent had a look like but hopfully not!
PostPosted: Sun Mar 11, 2012 10:10 am
Does what have to be a zetec? You can modify the cvh mount you have to fit, but not much point when Si mounts are easily available and bolt straight on
PostPosted: Sun Mar 11, 2012 11:39 am
The bracket the holds the rear engine mount is different for a mk3 thats not a zetec.
Whn you offer the zetec mount up against where it bolts too, it will become apparent of where the hole needs to drilled.
PostPosted: Sun Mar 11, 2012 7:58 pm
so i only need to drill for one engine mount or both front and back?
PostPosted: Sun Mar 11, 2012 10:47 pm
£20 posted
PostPosted: Mon Mar 12, 2012 9:36 pm
will pm u soon bud once ive checked finances.
PostPosted: Tue Apr 03, 2012 3:53 pm
got a rear one inc the bit that bolts to the block (zetec). i will make sure i haven't launched it in the skip. if its any use to you.
PostPosted: Tue Apr 03, 2012 5:30 pm
might well need that jam! ta buddy, let me knwo
PostPosted: Thu Apr 05, 2012 7:38 am
the only difference between the 1.4 si and 1.6 si is that the 1.4 wont have is the welded bracket on the chassis which is there for extra strength but you dont really need it, early mk3s zetecs didnt have it but if you want it to look genuine i have one ;)
PostPosted: Thu Apr 05, 2012 7:39 am
i also have rear engine mount complete and front engine mount minus crossover bracket
