Fiesta-Si.com • View topic - lost keys mk5
It is currently Mon Mar 23, 2026 5:26 pm
 Post subject: lost keys mk5
PostPosted: Fri Feb 03, 2012 11:58 pm
People:
2000 plate fiesta no keys.
Do I just get a new lock set, keys, ecu and ignition immobiliser ring from a donor car? or is the pats separate?
Is the easiest way in the coat hanger and bent door? :doh:
Thanks.
 Post subject: Re: lost keys mk5
PostPosted: Sat Feb 04, 2012 12:55 am
You just need a new ECU and chip mate, swap the chip into your key and your away. Can be any ZS ECU really, unless your running Decat in which it'd be better to have CLIP
Erm, could get a smith or AA out they can use an airbag, or you can get in the back windows with the little cirlce things and a screwdriver maybe.
I can find out on ZSOC as I know some people know how to get in, but they only PM people who need to know
PostPosted: Sat Feb 04, 2012 2:04 am
Get another ecu and a lockset with keys from another mk5 fiesta with the same ecu code, as for breaking into the car, there is loads of easy ways to do it but I won't be disclosing them on here, give a few body shops a call, they usually have a kit to do this sort of thing
PostPosted: Sat Feb 04, 2012 2:11 am
Do Mk5's have push handle to lock it or a pin on the top of the door?
The Fat Fake Xr2i
PostPosted: Sat Feb 04, 2012 2:33 am
Push handle
PostPosted: Sun Feb 05, 2012 7:45 am
cheers guys. it ain't a zetec its a hairdryer tappet 1.3. :-)
we got in easy.
PostPosted: Sun Feb 05, 2012 8:00 pm
ok, anybody got any ideas how to remove the old barrel without a key? grrrr....
PostPosted: Sun Feb 05, 2012 8:03 pm
Screwdriver?
PostPosted: Mon Feb 06, 2012 5:52 pm
drill and a 14mm drill bit
