Fiesta-Si.com • View topic - how do i reset my ecu?
It is currently Tue Mar 10, 2026 10:57 pm
 Post subject: how do i reset my ecu?
PostPosted: Tue Jan 31, 2012 11:12 am
Any idead...treads...links? Please anyone?
PostPosted: Tue Jan 31, 2012 12:14 pm
Disconnect the battery for about 30-40mins is the easiest way
PostPosted: Tue Jan 31, 2012 2:21 pm
And then what mate?
PostPosted: Tue Jan 31, 2012 2:27 pm
And then plug it back in! It should reset the ECU
PostPosted: Tue Jan 31, 2012 3:28 pm
Anyother ideas folks?
PostPosted: Tue Jan 31, 2012 3:33 pm
PostPosted: Tue Jan 31, 2012 4:00 pm
What do you mean another idea??? That's how you do it...
PostPosted: Tue Jan 31, 2012 8:01 pm
Leave it disconnected overnight to be sure.
PostPosted: Tue Jan 31, 2012 8:36 pm
Remove the ecu, and get a 12v wire and rub it across all the shiney pins.
PostPosted: Tue Jan 31, 2012 9:18 pm
So Danny I just take the negative off, leave it for 30 40 mins, then te connet it, un plug the ecu, plug it back in, then go for a drive I read some where? Yeah? There's so many driffant ways iv read, my head is lost, haha
PostPosted: Tue Jan 31, 2012 9:25 pm
Just leave the negative battery disconnected for about 30-40mins, then connect it again and all will be good. No need to disconnect the actual ECU. Then take it for a drive, should take about 20mins to re-learn, if that doesn't do anything, do what Percy said and leave it disconnected overnight and take it out in the morning :)
PostPosted: Tue Jan 31, 2012 9:31 pm
Thanks mate!!! Il try it!!!!
PostPosted: Tue Jan 31, 2012 9:35 pm
And re setting the ecu should by rights tell it iv put on a new maf and sort out mixure so it doesn't run so rich?
PostPosted: Tue Jan 31, 2012 9:40 pm
Correct
PostPosted: Tue Jan 31, 2012 9:47 pm
Thanks guys!!! Il try it soon :D
