Fiesta-Si.com • View topic - Ecu water pump sensor!
It is currently Mon Mar 23, 2026 5:27 pm
 Post subject: Ecu water pump sensor!
PostPosted: Thu Jan 19, 2012 10:52 pm
Attached to the manifold direct to the ecu. Can anybody tell me anymore about this as I have been told it could be the reason to my problem with my car? Any help or pics would be appreciated ;)
PostPosted: Thu Jan 19, 2012 11:25 pm
What engine??
What sensor you thinking? The one on the inlet?
PostPosted: Thu Jan 19, 2012 11:44 pm
It's a 1300 spi that's all I know sorry! Yeah on the inlet.
PostPosted: Thu Jan 19, 2012 11:49 pm
That would be the air inlet temp I'd imagine
PostPosted: Thu Jan 19, 2012 11:50 pm
I'll have a look in my Haynes tomorrow, could that stop the car from running?
PostPosted: Fri Jan 20, 2012 8:24 am
Well on a zetec if that sensor goes tits upbit throws the ecu out and causes issues with idle and fueling
PostPosted: Fri Jan 20, 2012 9:37 am
The car will start and run for a little bit very very lumpy, it'll cut out and not start again until maybe a few hours to a week.? Could that be this?
PostPosted: Fri Jan 20, 2012 7:52 pm
crank sensor or the spi unit is tossed. they were never a good idea when they were new. id go with the crank sensor first.
PostPosted: Wed Feb 01, 2012 9:22 pm
Cheers guys, what's the spi box and where would I find it lol
PostPosted: Thu Feb 02, 2012 5:23 pm
Hey guys I've been out at the car today and I've came across a plug that's not connected I don't know what it is and for the life of me just spent two hours trying to find somewhere where it could go, I can't upload pica but has 2 thin wires connected to it on is brown and yellow and the other is black? I can email thru my phone a picture and if one of you could be so kind to put it up?
PostPosted: Mon Feb 06, 2012 7:36 pm
what colour is the plug that is on it??? if it is white its for the air temp sensor
PostPosted: Mon Feb 06, 2012 10:43 pm
It's black mate, just seen your post
PostPosted: Mon Feb 06, 2012 10:49 pm
hmm ok now i am stumped lol, its a HCS engine you got isnt it, from memory there was a couple plugs not connected when i had mine, but to clear that up, where abouts is the plug???
PostPosted: Tue Feb 07, 2012 12:38 am
If you have a email address I can send u a picture? It's at the back of the engine bay just off centre to the right. Theres two plugs at the back of the bay one of the plugs has 11 wires on it?
PostPosted: Tue Feb 07, 2012 9:11 am
you have PM
PostPosted: Tue Feb 07, 2012 10:24 am
Replied. Cheers.
PostPosted: Tue Feb 07, 2012 10:40 am
got it, i am looking through wiring diagrams, doesn't look important, i can see from your pic that you had EGR on the car, going by the large holes in the head lol, it may be a connector for that... if so, get some blanking plugs and washers from ford and tuck wire out the way behind the edis module (the plug with 11 wires)
heres the pic if anyone else wants to comment...
PostPosted: Tue Feb 07, 2012 12:14 pm
Thanks a lot buddy, what is egr? Sorry if it's simple. I havent removed anything from when I got the car.
PostPosted: Tue Feb 07, 2012 12:21 pm
EGR is exhaust gas recirculaition...
used to put exhaust gasses back into the inlet to help with emissions...
you probably have a pipe going on the inlet which isnt attached to anything wich would make the car run pooh if not blocked off... and with the large holes on the exhaust side will leak exhaust gas into the engine bay not a good thing!!!!!
another thing, i had the starting issies with mine turned out to be the throttle sensor, wires had fallen to bits and shorted out, check the condition of the wires,- 3 wires notmally covered in a green sleeve next to the inlet
PostPosted: Tue Feb 07, 2012 2:08 pm
Cool I will give it a check later tonight and let you know, thanks for the help.
