Fiesta-Si.com • View topic - Fiesta ZS - Cursed :(
 Post subject: Fiesta ZS - Cursed :(
PostPosted: Mon Jan 16, 2012 9:54 am
car is cursed i swear:
had the following at garage: (ringing them back today)
Ford Water Pump
Ford Radiator
Ford Thermostat
Ford Temperature Sensor
Coolant Change
Fan has stopped blaring - but on motorway yesterday - temp gauge was moving again :( sigh - any ideas people?
PostPosted: Mon Jan 16, 2012 12:48 pm
head gasket
PostPosted: Mon Jan 16, 2012 1:46 pm
had a head gasket test at garage and no problem :lol: still pulls well - ahem :lol: - no oil or water usage
PostPosted: Mon Jan 16, 2012 2:10 pm
Clocks.
PostPosted: Mon Jan 16, 2012 2:42 pm
you reckon paul? what about ecu? :(
PostPosted: Mon Jan 16, 2012 2:53 pm
Well judging that everything else has been replaced.. I'm going on cheapest / easiest.
Clocks, then ecu. Wiring could be a factor if its damaged between the sensor and clocks.
First two, if you could borrow then that's better. But the clocks are cheap enough.
I would be tempted to fit an aftermarket temp gauge.
PostPosted: Mon Jan 16, 2012 3:03 pm
Cheers paul :)
PostPosted: Mon Jan 16, 2012 4:09 pm
air lock
could be a problem with the heater control valve as these are very prone to failure
PostPosted: Fri Mar 16, 2012 12:34 am
Seems they are prone to getting an air lock behind the thermostat so that it never opens - had this problem with mine. One solution is to drill a 2mm or 3mm hole in the edge of the thermostat, (or remove the loose pin that blocks the hole, depending which type of thermostat you have). Downside is that it takes longer to warm up, and can run a bit too cool on very cold days in winter.
Have a search of the ZSOC forum - that's where I found the answer.
Also briefly had occasional overheating on long motorway journeys. Only happened on 3 journeys (after being on motorway for an hour or two). Problem went away after I changed the fuel pipe from the tank to the fuel filter, (as it was leaking slightly at the connector). Seems unlikely that it was drawing air in and making it run weak, so probably just a coincidence, but it's been fine since.
PostPosted: Fri Mar 16, 2012 1:07 am
