Fiesta-Si.com • View topic - dash board clock dial question....
It is currently Wed Mar 11, 2026 5:52 am
PostPosted: Sun Dec 11, 2011 9:13 pm
as you sit in your 1600 efi fiesta si and turn the ignition key, in what order do the lights by the spedo dial clocks come on.... i.e abs, parking,battery etc....
anyone shed any light?
TEAM AUBERGINE
PostPosted: Mon Dec 12, 2011 2:44 pm
They should all come on (except lights and indicators), and then after about 5 seconds you should be left with the ignition light and handbrake light if it's on.
PostPosted: Mon Dec 12, 2011 6:48 pm
TEAM AUBERGINE
PostPosted: Mon Dec 12, 2011 9:28 pm
The one with the pic of the battery and oil can thing on it
PostPosted: Tue Dec 13, 2011 7:40 pm
TEAM AUBERGINE
PostPosted: Tue Dec 13, 2011 8:01 pm
Battle light goes out soon as you start the engine. If it stays on with engine running that shows a fault with the battery circuit (alternator issues, dead battery)
PostPosted: Tue Dec 13, 2011 10:50 pm
As a standard start, turn the key to position II which should light the battery, oil, handbrake and airbag light. On turning to the start position battery light should go out when the car is started (it's kind of normal for the battery light to hang on half a second for an old fez), followed by the oil light going out either straightaway or after about 3 seconds. After 5 seconds (or it's up to 10) the airbag light should go out too.
