Fiesta-Si.com • View topic - GTI inlet manifold
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: GTI inlet manifold
PostPosted: Sun Nov 27, 2011 5:42 pm
hey all
i'm thinking of swapping out the HO for the GTI inlet on my 1.8 zetec fezza. as i heard it has better resistance against heat soak, i already have the inlet manifold, but it doesnt have provisions for a inlet temp sensor... will i then have to find an ext. pats ecu/engine loom or can i use the rs1800 loom i got and mount a temp sensor somewhere?
cheers
 Post subject: Re: GTI inlet manifold
PostPosted: Sun Nov 27, 2011 10:36 pm
keep the HO manifold :)
PostPosted: Tue Nov 29, 2011 9:03 pm
yea i dunno if i like it really, my strut brace catches on it and annoys the hell out of me...
PostPosted: Thu Dec 01, 2011 2:18 pm
You sure the gti manifold will fit due to the brake bar and bulkhead?
All you'd need to do is make a hole for the inlet sensor, and run your normal loom.
But just stick with the ho inlet.
If it hits your strut brace, something is wrong.
PostPosted: Thu Dec 01, 2011 2:23 pm
OMP strut brace I bet...
PostPosted: Thu Dec 01, 2011 8:42 pm
i have fitted a gti inlet and clears the mk3 brake bar etc and fits in perfectly!! i have a spare one lying around mate if you want it to test it??
PostPosted: Fri Dec 02, 2011 8:05 am
I see no benifit from fitting one tho.. HO inlets work fine.
PostPosted: Sat Dec 03, 2011 12:15 am
he's worried about the heat soak as the inlet pipe goes over the engine and can heat up the air travelling in, as where the plastic inlet has very good flow and can be used in turbo applications too! and also diverts the air intake around the engine, but i think you need to remove the battery and place it elsewhere in the boot or foot well etc
PostPosted: Sat Dec 03, 2011 3:34 pm
Hmmm. Fair enough I guess.
Cold air feeds and a better placed air filter would be good enough IMO.
PostPosted: Mon Dec 05, 2011 1:06 pm
lol yep omp brace, how did you guess????
i also want to use the GTI as the inlet pipe is quite large (70mm iirc) to match the ports on the maf and inlet which is hitting the bonnet and wont close fully...
i can work out the filter arrangement after... fit a fully cased filter with cold feed pipe into the si bumper somewhere...
PostPosted: Mon Dec 05, 2011 1:11 pm
Because the OMP one isn't made for Zetecs, despite being sold for them. I found this out the hard way when mine rubbed on my inlet manifold and shook the car to bits. Had to ditch it. The angle on the brace isn't enough to comfortably clear the inlet. There's been a couple of people that have said they fitted one with no rubbing, but it must have been tight.
PostPosted: Mon Dec 05, 2011 5:11 pm
yea its only just rubbing it, but like you say it vibrates like nuts...
PostPosted: Mon Dec 05, 2011 5:14 pm
Mod it! Get it bent!
PostPosted: Tue Dec 06, 2011 11:23 am
nah screw that... it will look poo if i do that!!! lol
PostPosted: Wed Dec 07, 2011 2:02 pm
aparently the 2.0 litre blacktop focus is a better one to use again
PostPosted: Thu Dec 08, 2011 2:42 pm
PostPosted: Thu Dec 08, 2011 10:40 pm
Yes they do.
Fit the silvertop sensors tho.
PostPosted: Fri Dec 09, 2011 12:16 pm
yeah they fit in the mk3 bay, need to fit the silvertop sensors as happypaul said
PostPosted: Fri Dec 09, 2011 2:34 pm
cool will look for one of those then... cheers guys
PostPosted: Fri Dec 16, 2011 4:45 am
im positive the H.O one is the best you can get for the ph1 and 2 without going to other manufactures
