Fiesta-Si.com • View topic - Clunky steering problem
 Post subject: Clunky steering problem
PostPosted: Tue Nov 22, 2011 4:39 pm
I have a 1995 mk3 fiesta with a clunky steering problem it's had a new steering joint and still does it.... What can this be?
PostPosted: Tue Nov 22, 2011 4:48 pm
Any more details? When does it clunk? What part of the steering range does it clunk? Does it clunk when the car is still?
Have you had a look down at the track rod ends, ball joints on the lower arms, and checked the wheel bearings?
PostPosted: Thu Nov 24, 2011 2:40 am
yehh it does it if the car is moving or stilll.... track rod ends are fine and still tight all wishbone's and so on are fine i think it may be the rack that has worn if i hold the rack and get a mate to turn the wheel i can feel it grinding ... not smoth at all
PostPosted: Mon Nov 28, 2011 7:14 pm
sounds like either the rack or the universal joint at the bottom of the collumn, is it power steering? a non-p/s rack from a motor factors is about £30 and a new genuine UJ is only about £15
