Fiesta-Si.com • View topic - water leak
 Post subject: water leak
PostPosted: Mon Nov 14, 2011 4:25 pm
i have a bad water leak but cant see where its coming from, as fast as im putting water in its just pouring out from underneath near the alternator, would would it most likely be? hoses or water pump? i really need help with this as im not very good with anything under the bonnet, its not drivable while its like this as it gets far to hot and cuts itself out. but its not holding any water at all, iv tried putting additives in it to plug up anything there might be but had no luck
help would be great.
cheers
 Post subject: Re: water leak
PostPosted: Mon Nov 14, 2011 4:33 pm
If it's coming out that fast you have a loose hose clip at best. You will need to get in the engine bay and look for anything not attached correctly.
PostPosted: Mon Nov 14, 2011 5:47 pm
Failing that its the waterpump, if it is that then dont attempt to drive it because the timing runs the water pump and you dont want that snapping
PostPosted: Mon Nov 14, 2011 9:54 pm
either gonna be the water pump or the hose from the pump to the rad
PostPosted: Wed Nov 16, 2011 10:31 pm
well just to be on the safe side im gonna buy a new water pump anyways, its only £16 so just to be safe i might aswell, will find out what it is tomoz. fingers crossed nothing else is wrong
cheers for advise
PostPosted: Wed Nov 16, 2011 11:38 pm
i would advise getting a timing belt kit aswell as you will have to remove the timing belt to get at the water pump
PostPosted: Wed Nov 16, 2011 11:54 pm
thats what did with mine,saves money in the long run
