Fiesta-Si.com • View topic - canister solenoid purge valve
It is currently Tue Mar 10, 2026 10:57 pm
PostPosted: Thu Oct 27, 2011 9:16 am
as title what are they used for on the 1.4 si as my bro as got the same engine in his mk2 fezz but it is blanked off
blunty
PostPosted: Sat Oct 29, 2011 4:51 pm
emmisions i think, its useless.
PostPosted: Mon Oct 31, 2011 10:22 pm
i think it helps with idle too but not sure
PostPosted: Thu Dec 15, 2011 12:56 pm
sorry to jump this...
so it can be removed and have the 2 pipes that run to the valve joined up??? would that be ok???
PostPosted: Fri Dec 16, 2011 4:43 am
your meant t blank them at the exhaust, you can buy the caps from ford i think
PostPosted: Fri Dec 16, 2011 12:42 pm
PostPosted: Fri Dec 16, 2011 2:35 pm
oh crap shows i was reading lol
i get confused which one is that one?
PostPosted: Fri Dec 16, 2011 7:41 pm
lol
canister purge valve is a valve that is switched on by the ecu to vent vapor from the fuel tank into the inlet to burn it off... apparantly
EGR is those gay lloking pipes that come off the exhaust manifold back into the inlet to be reused and do something with the mixture to reduce emmissions... again apparantly lol
