Fiesta-Si.com • View topic - Heater blower not working at all
It is currently Wed Mar 25, 2026 10:08 am
PostPosted: Sun Sep 04, 2011 12:12 pm
Any advise please? My heatre blower has stoped working all together. About 2 years ago i changed the reistor thing in the pasanger foot well as it had stoped working on position 1 and all has been well until a few weeks ago when it sudenly stopped working on all speeds without any warning at all. My local garage say they cant find the problem and told me to go to an auto elactrician but i think they was too busy to realy look properly.
Is it the switch or the blower or what and if so how can i test them please?
Any thought or ideas please? :(
PostPosted: Sun Sep 04, 2011 12:53 pm
resistor needs changing. its located behind the firewall next to the fan motor
PostPosted: Sun Sep 04, 2011 3:26 pm
isnt the resistor the little thing in the pasenger footwell though ?
PostPosted: Sun Sep 04, 2011 3:30 pm
Or is it something else please?
PostPosted: Sun Sep 04, 2011 5:30 pm
nope, its next to the fan blower motor
PostPosted: Sun Sep 04, 2011 7:31 pm
Is that the little silver thing i can see by the pipes with wires pluged into it under the bonet near the windscreen please?
Please excuse my ignorance lol
Mine is a S reg mk 4 fiesta 1.3
PostPosted: Sun Sep 04, 2011 8:34 pm
yeah more than likely, its retangular with loads of little holes in the casing and has metal coils inside it, should be about 4 wires going to it i think
PostPosted: Sun Sep 04, 2011 9:28 pm
you probably need a new heater control valve if its not working on any setting
PostPosted: Mon Sep 05, 2011 4:59 pm
if it was the resistor it work work on the fastest setting, sounds like either the switch, the fan or the live feed to the fan have broken
PostPosted: Mon Sep 05, 2011 7:07 pm
Is there a way that i can test the switch please? Which wires should i bridge at the back of the switch to bypass the switch and eliminate it as the problem please? :? :(
PostPosted: Tue Sep 06, 2011 2:05 pm
Use a multi meter to find out which cable is permanent live then go from there, pretty straight forward once you know that
PostPosted: Wed Sep 07, 2011 7:14 pm
Can anyone please help me with an idiot guide of how to do this please ?
Users browsing this forum: Bing [Bot] and 56 guests
