Fiesta-Si.com • View topic - immobiliser help
 Post subject: immobiliser help
PostPosted: Sat Aug 13, 2011 7:20 pm
iright sorted my problem down to being the imob.
its kicking in all the time and not letting the car start. started once
in 2 months and when i turned it off it started straight away and20mins
later it didnt. the red light under my clock stays solid when turning the
engine over and doesnt flash when the car is locked or unlocked or anytime really.
any help or suggestions on this would be appreciated .
 Post subject: Re: immobiliser help
PostPosted: Sat Aug 13, 2011 10:55 pm
http://fiestamk3parts.com/guides/usefull-info/p-a-t-s/
PostPosted: Sun Aug 14, 2011 3:44 pm
Got a spare key to try?
PostPosted: Sun Aug 14, 2011 6:35 pm
i got three keys with my car. ones a right thick one with a wee red square on it but it doesnt turn in the ignition it only opens the car dont know if thats anything to do with the master key. the othr 2keys usually start the car. wherw can i get a masyer key and how much will it be?
PostPosted: Mon Aug 15, 2011 12:28 am
You won't get another master key, but you can get new keys cut from what you have, have you tried to start the car with the wrong key?? If not possible problems could only be the key, transponder ring, wiring or the pats unit it's self
PostPosted: Mon Aug 15, 2011 8:39 am
yeah the big thick key dont turn in the ignition just the two others.
so id need two other keys?
and then what. sorry if im being simple just dont want to be missing anything out.
PostPosted: Mon Aug 15, 2011 10:16 am
so the 2 keys that used to start the car are the thin type with no red square on top? but now do not start the car? and the key with the red square on it only opens the door? does it work all the locks apart from the ignition barrel?
PostPosted: Mon Aug 15, 2011 3:20 pm
yes mate exactly. you heard of this before?
PostPosted: Mon Aug 15, 2011 8:14 pm
anybody know how to get around this problem with pats
PostPosted: Mon Aug 15, 2011 9:49 pm
Hold the key with the red chip in it as close to the barrel as you can and use the other key to try and start it
PostPosted: Mon Aug 15, 2011 10:05 pm
ill try it first thing in the morning its usually on the key ring as well. let u know how i get on. thanks mate
PostPosted: Thu Aug 18, 2011 1:00 pm
still not working guys, any other ideas
PostPosted: Thu Aug 18, 2011 2:40 pm
Have i got this right? The thin keys used to start the car?
The thicker one must have the chip in it and the imobiliser must of been picking it up, just, even though its a bit further away from the transponder ring (around the ignition barrel). However for some reason its not now.
Have you tryed taking the cowling off around the column, taking the chip out of the key, and tape it too the transponder ring.
For some unknown reason it might not like picking the signal up now.
PostPosted: Thu Aug 18, 2011 2:47 pm
ps it shouldnt flash at all when locking or unlocking car.
PostPosted: Thu Aug 18, 2011 8:41 pm
i just hooked my other car up to jump start the car held the thick key close to the barrell as possible
and it started first time went a wee drive i a car park over from me and it was fine. i stopped the engine running and it
started again. BUT yes there is a but it done this before so im gonna go back out in half hour to see if it starts again and ill let u guys know.
PostPosted: Thu Aug 18, 2011 10:26 pm
she started again guys well chuffed will see in the morning now fingers crossed, is there a battery or anything i could change tomake the signal stronger?
PostPosted: Fri Aug 19, 2011 10:40 am
amazing.....she started. well chuffer now i need to brave a drive and hope she dont break down lol
thanks for all ur help guys but i might be back in tgis section hope not
PostPosted: Fri Aug 19, 2011 3:01 pm
unfortunately there is no battery in it. Not to sure how it works exactly.
Good job its working though.
PostPosted: Fri Aug 19, 2011 5:32 pm
so after coming home from the cinema i decided to take her for a jaunt and guess what.........yup back to square one
PostPosted: Sat Aug 20, 2011 1:04 pm
did you charge the battery?? if voltage is low the PATS unit won't recieve a strong enough signal to work
