†Ûi³ÿßrȬþ;
ob_start();
†Ûi³ÿßrȬþ;
ob_start();
[phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4769: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4770: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4771: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19)
Fiesta-Si.com • View topic - leaking ALOT of water
wondered if anyone can help me, my car just started to cut out when slowing down or coming to a stop, i noticed the temperature was in the red so i stopped to put water in and it was bone dry ( filled it right up last week) now its coming out quicker than i can get it in there but cant see where its leaking from, i can only see that its leaking down and dripping new the altenator any help would be great
if you have overheated it I garantee it's the core plug in the head, behind the camp pulley, pop off thetip half of the cambelt cover and pour some water in, if the water pump went the car wouldn't start as the cvh/pte engines water pump in driven by the cambelt as opposed to six belt driven on the zetec
If that core plug has popped out and you have driven and overheated it, then it'll be beyond repair, would be cheaper to replace or upgrade the engine, check and see where the water is coming from cus if it's the water pump it's cheap and easy fix
