Fiesta-Si.com • View topic - please help on engine problems!!
PostPosted: Fri Feb 10, 2006 11:02 pm
I have just bought an si. When accelerating, it hesitates for a few seconds (feels a bit like turbo lag) but when the power eventually kicks in, the car performs normally. This delay can be anything up to about 10 seconds. I have plugged my car into the OBD (on-board diagnostics tester) in college and it came up with 2 faults, one was AIR INTAKE and the other was NO o2 READING. Im guessing the o2 reading is probably the lambda sensor but im not sure it would effect acceleration. When I unplug the air-flow sensor, the problem goes but the car is generally a lot slower. Does this definatly mean that the air flow sensor needs replacing or could the problem be something else? any ideas? many thanks,
Emlyn (sorry its quite a long post lol)
PostPosted: Sat Feb 11, 2006 1:01 am
it sounds like it'll be lambda sensor, MAF or TPS(throttle position sensor) you could try cleaning the MAF, and if that doesnt cure it try changing the lambda sensor
PostPosted: Sun Feb 12, 2006 3:33 pm
cheers mate i'll give it a try
thanks a lot
