Fiesta-Si.com • View topic - ECU info
 Post subject: ECU info
PostPosted: Sat Jun 25, 2011 5:20 pm
does the "2fbc" ECU from an RS1800 have built in edis with either external or no PATS at all??
cheers, Tony
 Post subject: Re: ECU info
PostPosted: Mon Jul 04, 2011 9:06 pm
It's an external edis ecu with no pats, it won't work with an si loom
PostPosted: Wed Jul 06, 2011 12:37 pm
cheers mate, i thought that was the case as they're pennies compared to a deep, desk, dewy ecu, so the only ecus for a zetec with no pats and internal edis that will work with the si/ghia loom are
DEEP, 130 spec mondeo + 4x4 mondeo
DESK, 130 spec mondeo
DEWY, 130 spec mondeo
DALE???? later (1995? ) spec 130 spec mondeo but with external pats?? is the wiring the same?
CULT, 130 spec fiesta rs1800
BLOB, 105 spec mondeo 1.8,
and GURU 90 spec fiesta 1.6
is this correct?? as i don't care what ecu i have in just so i can get the car running, then i'll fit the correct ecu, are the ecus remappable or can a GURU ecu be chipped to be equal to a 130 spec ecu??
