Fiesta-Si.com • View topic - Question for those who have done the Mondeo Servo Mod
PostPosted: Mon Jun 13, 2011 11:36 pm
Did your brake pedal sit an inch or two lower as well? Movement seems fine, it's just, lower.
PostPosted: Thu Jun 16, 2011 6:41 am
Cant understand why it would sit lower, but I havent done the mondeo mod before, just an escort one and the pedal was the same.
PostPosted: Thu Jun 16, 2011 1:20 pm
i think it might be to do with the rod length out the back of the mondy servo but not sure, i know for for the mk1s and 2s it has to be cut and welded to make it like 19mm long or something
PostPosted: Thu Jun 16, 2011 1:37 pm
Escort ones need modding.
Mondeo ones do not.
PostPosted: Thu Jun 16, 2011 1:59 pm
PostPosted: Thu Jun 16, 2011 2:28 pm
Dunno, i'm putting my mondeo servo on in the next week or so, so if i have the same problem then you know that it's meant to be that way. If not... i don't know what to suggest
PostPosted: Thu Jun 16, 2011 2:32 pm
Well as far as I can tell it shouldn't affect the operation as it's now very tight and hard like a brand new car's brake pedal.
PostPosted: Thu Jun 16, 2011 3:54 pm
Just sits lower?
PostPosted: Thu Jun 16, 2011 4:05 pm
You bled everything up correctly?
PostPosted: Thu Jun 16, 2011 4:27 pm
Lol when i put my new brake setup on i had to turn the car around so i could bleed the system, went down the dropped kirb, pressed the brakes - FFFFFFFFFFUUUUUUUU! It was like bicycle brakes on a car haha.
PostPosted: Thu Jun 16, 2011 5:31 pm
PostPosted: Thu Jun 16, 2011 7:21 pm
Adjust your rear brakes and see where the pedalsits then, check to see if the rear wheel cylinders are weeping too
PostPosted: Thu Jun 16, 2011 8:11 pm
