Fiesta-Si.com • View topic - Gear nob like a stick in a bucket help !!
It is currently Tue Mar 10, 2026 11:02 pm
PostPosted: Wed Jun 08, 2011 11:24 pm
Hi there my fiesta rs1800 gearbox is the worst am thinking about changing the box what would be best ?? Diesel box or LSD box any ideas plz
PostPosted: Wed Jun 08, 2011 11:55 pm
lsd box from a series two would be good, but you can always buy or modify a normal ib5 gearbox, install an lsd etc and you can install a puma gear linkage which will act as a short shifter!!
PostPosted: Thu Jun 09, 2011 8:12 am
if as by the title 'gear nob like a stick in a bucket' its more likely the gear leaver linkage than the actual gearbox problem
PostPosted: Thu Jun 09, 2011 12:10 pm
well what it is av got a rs1800 am taking engine out to do the 2litre conversion (bored) and i was thinking about doing the box but not sure what to do with it the cars top end is s*** then theres the gear stick problem lol i have come down from a 400bhp scobby to the st170 then back to my rs1800 which i have owned for a year now just want to make it drive better any ideas or help i would be buzzing lads :thumbsup:
PostPosted: Thu Jun 09, 2011 7:54 pm
i think if you wanna make it drive better then stick an ib5 gearbox on from a zetec engine'd escort where the starter motor is at the back therefore you an fit a nice four branch manifold on with ease without affecting heat soak to the starter motor, and also fit a puma 1.7 gear linkage so you get a shorter gear change!!
PostPosted: Fri Jun 10, 2011 11:31 pm
rs1800 box top end shit????
its the best ratio'd fiesta box going!
if you want top end speed, derv box.. never top ended that and Ive been off the clock with that
oh yeah, dont fit a puma linkage.. its a load of bollocks.
PostPosted: Fri Jul 01, 2011 2:57 pm
it will be the springs in the gear stick mate the selector box
PostPosted: Wed Jul 06, 2011 12:42 pm
sounds like the linkage is buggered, buy a low milage second hand one or fit a new one if they're still made, if your doing the 2.0litre conversion, are you replacing the ecu??, if so what code is it?? could be intrested
