Fiesta-Si.com • View topic - cuts out then dont start
It is currently Mon Mar 23, 2026 8:32 pm
 Post subject: cuts out then dont start
PostPosted: Tue May 10, 2011 9:03 am
well yet agin my fiesta has broken down :x
it cuts out then it does not want to go any one got any idears ?
cheers rob
PostPosted: Tue May 10, 2011 9:42 am
well its runing again but not right :(
PostPosted: Tue May 10, 2011 10:07 am
Care to expand on what it's doing?
What was it doing after it cut out and you tried to start it? And how's it running now?
PostPosted: Tue May 10, 2011 10:16 am
well i drive of my drive when to the bottom of the road and it statd to jump can hot run right i reved it it was fine went around down the road and it cut out like the other day so i tryed to bump it off 1st gear again it was having none of it and then to people helped my run with it and stid did not want to start so put it on the side off the road and left it and rang me dad and thne wehn it start it still nothing left it for a hour is and it started but is runny ruff :( hope this help sorry for the vage other 2 post :(
rob
PostPosted: Tue May 10, 2011 10:56 am
Have you checked all sensors?
PostPosted: Tue May 10, 2011 1:42 pm
yes bud me dad just looked at it and he thinks it the timing to the disssy so i am geting my tappets and that cheacked
hope it a cheep fix :)
PostPosted: Wed May 11, 2011 11:31 am
do you have a good spark it should be a strong blue one if its yellwo you have a weak spark
check the voltage at the crankshaft sensor and coil pack also have you give it a service plugs leads fuel filter air filter etc
PostPosted: Wed May 11, 2011 2:54 pm
it will be single point injection so won't have a dizzy i think :hmm:
PostPosted: Wed May 11, 2011 3:44 pm
it had new oil the lot
they dont have a dissy they have a coil pack i think
well i have a crank senser coming to night but to day it seams ok it just went to go but rev it and it seems ok
cheers rob
PostPosted: Wed May 11, 2011 8:29 pm
well i have a new coil pack and the crank senser will get it fitted tomorrow night all being well
PostPosted: Thu May 12, 2011 4:42 pm
my car is in the middle of this at the moment and i think its my fuel cut off switch but im on a course at the moment so cant try it but try yours if you have 1 mate?
PostPosted: Thu May 12, 2011 5:11 pm
it ant the cut off because it runs some days fine like today
PostPosted: Mon May 16, 2011 2:29 pm
its now done thanks for the help
when i changed the crank sensor it stoped it not starting but it still died but started so changed the coil pack and it running sweet now :)
