Fiesta-Si.com • View topic - Mk 3.5 steering wheel and ignition barrel on Mk3?
PostPosted: Mon May 09, 2011 5:03 pm
Hi lads, Currently changing over bits from an Si into a mk3 shell,
Problem i have at the moment is fixing the ignition barrel and steering wheel to the rack,
I have it on but theres way too much play in the wheel and barrel rather than the rack?
Why is this if anyone knows?
Has it anything to do with not fixing the steering brace thats not normally in the mk3s?
Cheers!
Jason.
PostPosted: Mon May 09, 2011 9:27 pm
they should just swap straight over can you take a pic of it
PostPosted: Mon May 09, 2011 9:39 pm
Think ive solved the problem.. Tried a longer screw that goes threw the indicator stalks and the barrell to lock it onto the steering shaft, plays gone but the teeth on the steering wheel are now scrubbing on the barrel were the steering lock mechanism is..... grrr always something :doh: :lolz: :lolz:
PostPosted: Tue May 10, 2011 5:48 pm
did you fit the white spacer ring between the lock and wheel ?
PostPosted: Tue May 10, 2011 7:35 pm
No dont think so, would you post a pick of what it looks like? if thats k?
More than likely i spose is the solution! :D :D
Cheers.
PostPosted: Wed May 11, 2011 11:40 am
theres a white bush that goes in between the lock and the steerring wheel
