Fiesta-Si.com • View topic - 2 litre conversion, oil pump questtion
PostPosted: Sat Apr 30, 2011 5:27 pm
can i keep 2 litre pump and use cvh filter? im sure i read somewhere you can but cant find it now :doh:
cheers!
PostPosted: Sat Apr 30, 2011 7:12 pm
yeah thats right you can use the shorter cvh filter!
PostPosted: Sat Apr 30, 2011 7:33 pm
so would i be able to use a cvh filter with a standard rs1800 engine or just the standard zetec 1 thanks :thumbsup:
PostPosted: Sat Apr 30, 2011 10:12 pm
When I put the 2.0 in mine I kept the 2.0 oil pump and used a ka oil filter.
PostPosted: Sun May 01, 2011 12:46 am
Yeah the cvh oil filter just gives ya enough clearance you need but will need to be changed sooner though.
PostPosted: Sun May 01, 2011 1:40 am
Cheers for the replys confirmig i can use the filter :thumbsup: Dont mind having to change it more often as i tend to change oil an filter every 4 month now anyway
PostPosted: Sun May 01, 2011 2:41 am
PostPosted: Sun May 01, 2011 11:04 am
PostPosted: Sun May 01, 2011 1:06 pm
The cvh filter is pretty much the same as a zetec item except its an inch shorter in length, perfectly fine to use aslong as you change oil a bit more often which you said you are
