Fiesta-Si.com • View topic - NEED HELP ASAP PLEASE
It is currently Wed Mar 25, 2026 10:39 am
 Post subject: NEED HELP ASAP PLEASE
PostPosted: Sat Apr 16, 2011 6:44 pm
my car started playing up a few weeks ago and i thought it was because there was no back box on it.
basically the car starts and drives (when suits) it seems like there is loss of power and it feels like fuel is not getting through properly so i replaced the fuel filter and someone said it might be the H.T leads so i again tried this also spark plugs and then onto a full service i have replaced the exhaust now and its still not working properly any ideas would be greatly appreciated. whenever i put any revs into the car it dies and struggles to get running again. my car is a 1300 ghia.(not a si but as good as someone on here said at 1 point)
i am in desperate need of help with this as i need this car for work
even if someone can call or text that would be great. 07889794438
cheers in advance matty-o
PostPosted: Sat Apr 16, 2011 6:49 pm
Tried the lambda? Try disconnecting that if that's not it could be the coilpack
PostPosted: Sat Apr 16, 2011 7:03 pm
will it still work if the lamda is disconnected? cheers for the prompt reply chris mate.
PostPosted: Sat Apr 16, 2011 7:15 pm
clean the maf sensor :)
PostPosted: Sat Apr 16, 2011 7:18 pm
cheers but can i be a tube and ask where these are? lol
PostPosted: Sat Apr 16, 2011 7:51 pm
does these symptoms happen even at idle or not?? please guys i need this done cheers
PostPosted: Sat Apr 16, 2011 9:49 pm
Could be idle control valve, might be either dirty or worn out, i would clean out your throttle body too
PostPosted: Sun Apr 17, 2011 11:59 am
lambda sensor it was guys, thanks alot guys for the promp reply.
PostPosted: Sun Apr 17, 2011 5:29 pm
car aint starting now not getting a spark think it could be the coil but not too sure
PostPosted: Sun Apr 17, 2011 7:12 pm
To which point have you tested the spark to? Could be a few things like plugs, to the leads or the cps sensor, coil packs are fairly common on fords, i would start by checking all your cabling plygs are all connected correctly first
PostPosted: Sun Apr 17, 2011 9:36 pm
yeah tested for spark mate and nothing, checked all plugs and they seem to be in order.
all HT leads and plugs are new there is fuel getting to the carb but just not igniting.
tried to bump it to but nout. start a new job tomorrow luckily i dont need it but my hours are much longer
