Fiesta-Si.com • View topic - rs2000 wheels spaced?
 Post subject: rs2000 wheels spaced?
PostPosted: Tue Apr 12, 2011 8:28 pm
stupidly only bought 2 spacers as i only fitted them to the front. will the rears need spacers also?
grazy
PostPosted: Tue Apr 12, 2011 8:36 pm
ive only got spacers on the front so the brakes dont rub and it seems fine to me
i was thinking of getting rear ones tho u can see the difference between the back and the front :lol:
PostPosted: Tue Apr 12, 2011 8:47 pm
You only need the front, get some axle spacers :D
PostPosted: Tue Apr 12, 2011 8:57 pm
they're an absolute pain to fit though arent they? if its obvious jamie ill invest in ones for the rear!
PostPosted: Tue Apr 12, 2011 9:32 pm
Axle spacers are easy to fit, jack to car up and rest on axle atands, remove the wheels, remove the 30mm hub nut, knock the drum off, remove the 4 19mm nuts holding the stub axle on, underneath the stub axle there will be 2 rivets holding the backing plate (that the brake shoes are attached to) to the rear beam, drill these 2 out gently tap the backing plate off, fit the axle spacer on and bolt the stub axle back on, there is no need to use rivits again, they are only used as a guide for the 4 19mm bolts, then refit in reverse order
Cheap tip, ford ka's come with axle spacers as standard
PostPosted: Wed Apr 13, 2011 4:46 pm
sounds like a bit of a ball ache :P wheel spacers will do for now.
you want them springs btw tonwah?
PostPosted: Wed Apr 13, 2011 5:15 pm
its not ballache and its much better than spacing out the wheels on the studs, seeing as you'll have less stud for the nut to screw onto, whereas with spacers on the axle you get longer bolts etc so nothing really changes. Might be more stress on the studs spacing the wheels out more :)
PostPosted: Wed Apr 13, 2011 6:01 pm
yeah true, maybe that's why yours shanked? only 5mm though so cant see it doing too much damage, just make sure they're nice and tight
PostPosted: Wed Apr 13, 2011 6:16 pm
No because I don't have spacers.
PostPosted: Wed Apr 13, 2011 6:47 pm
maybe not then
PostPosted: Wed Apr 13, 2011 11:27 pm
Just relised i have a pm from you!
