Fiesta-Si.com • View topic - PATS problem :( help
 Post subject: PATS problem :( help
PostPosted: Fri Apr 01, 2011 7:15 pm
 Post subject: Re: PATS problem :( help
PostPosted: Fri Apr 01, 2011 7:42 pm
If you want to initiate a new master key....
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position. The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder OFF and then back to the ON (RUN) position. The security light on the dash will flash for fifteen more minutes.
3. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder to OFF and then back ON (RUN) position. The dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been programmed into the vehicles computer and will operate the car. It has replaced ALL the previous electronic key codes and is the ONLY key programmed into the vehicles computer.
If you want to add a key....
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within 15 seconds, insert the new key and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming the key into the vehicle.
5. Don't attempt to start the vehicle with any key for at least 1 minute.
PostPosted: Fri Apr 01, 2011 10:20 pm
thats some great info mate :)
PostPosted: Fri Apr 01, 2011 10:48 pm
PostPosted: Fri Apr 01, 2011 11:28 pm
Awesome gen :thumbsup: Will definately help when I get my new key
PostPosted: Sat Apr 02, 2011 9:43 am
Wow. Thanks alot I will have a go today :)
PostPosted: Sat Apr 02, 2011 9:49 am
just get the pats removed like mine ;)
PostPosted: Sat Apr 02, 2011 10:00 am
Also I have a different reader in my car from a mk 4 using a mk 4 lead would that make a difference?
PostPosted: Sat Apr 02, 2011 10:03 am
How do I remove pats? That sequence didn't work?
PostPosted: Sat Apr 02, 2011 10:41 am
The code is 1:3 meaning key code not registering
PostPosted: Sun Apr 17, 2011 10:57 pm
dunno its says in my service history that its been bypassed and theres now working led on the clock :)
