Fiesta-Si.com • View topic - dammit ecu dropped into car can't disconnect it.
It is currently Wed Mar 25, 2026 11:08 am
PostPosted: Fri Mar 18, 2011 9:01 pm
ok so ECU is currently lose in the passenger footwell but I cant get it to disconnected from the loom help please.
as simple as possible please :frown:
PostPosted: Fri Mar 18, 2011 9:45 pm
loosen the cage the ecu normally sits in
push the ecu back into the cage and tighten it back up
then go into the engine bay top passanger side undo the two bolts holding the loom cover inplace.
once disconnected pull the cover out of the way and unscrew the centre bolt in the loom plug and once loose pull the plug off
PostPosted: Fri Mar 18, 2011 9:51 pm
it was dropped through but as it was the original guru one it was being stubborn.
got it now and the deep one is in place.
now time to test....
PostPosted: Fri Mar 18, 2011 10:50 pm
yes we are sorted :D
idle is 100x better. the ECU is still learning as it's never been in a car but the power is lovely.
PostPosted: Fri Mar 18, 2011 11:02 pm
:thumbsup: Glad its sorted after all the agro!
