Fiesta-Si.com • View topic - removal and refitting springs?
It is currently Mon Mar 23, 2026 8:32 pm
PostPosted: Thu Mar 10, 2011 7:30 pm
not sure if im right but it's a job for the garage to swap over springs? or can it be done by oneself?
cheers
PostPosted: Thu Mar 10, 2011 7:35 pm
done by yourself, You should treat yourself to a haynes manuel, tells you everything lol.
PostPosted: Thu Mar 10, 2011 7:41 pm
lou, i have one! :doh: :lolz:
im a lazy sod, sometimes easier to just ask on here :D then i get helpful chaps like yourself saving me walking miles.
good news though, cheers :thumbsup:
btw this is to change the springs off the shocks completely onto other shocks, right?
PostPosted: Thu Mar 10, 2011 7:46 pm
just need some spring clamps cost about roughly £20 for a decent set. you will need a 1/2 inch ratchet or impact gun to help compress the springs. long breaker bar helps on the tough hub nuts etc! the rears are easier as there less bolts, the fronts maybe a little tricky!
PostPosted: Thu Mar 10, 2011 7:50 pm
lol cheers sleeman, defo a trip to the garage! how much would they charge to do it?
PostPosted: Thu Mar 10, 2011 11:00 pm
do it yourself it is not hard i have changed the backs and did not need spring clamps but the fronts i have only changed the whole shock but the springs feel alot more compressed so i would recommend using spring clamps for the front if just changing the springs as i have not had them apart so i wouldnt no
try taking the back shock off and having a look if you dont feel confident then dont do it but but as soon as it is off i bet you say this is easy as i had never done nothing on a car a year a go but have now done a few things like clutch change, services, shocks, exhaust, etc just take your time and only way to learn is to do it imo :thumbsup:
PostPosted: Thu Mar 10, 2011 11:07 pm
hmmm garage costs with all parts provided that is, its probably about 2-3 hours labour.
PostPosted: Sat Mar 12, 2011 10:44 am
It'll be expensive at a garage and it's easy to do yourself.
Rears you just jack it up, off with the wheel, off with the bottom bolt on the shock, off with the top nut in the boot on the turret, then you have your shock. take the top nut off and you'll reveal your spring, remember how everything goes back together, take the spring off, put new spring on, put it all back together and bolt it all back in. Simples.
Fronts are the same you just have to undo two more bolts which are right in front of you when you take the wheel off.
PostPosted: Sat Mar 12, 2011 10:49 am
Just give it a go lol.
PostPosted: Sat Mar 12, 2011 1:41 pm
i would say i can do it for you if you don't feel up to it. then i realised how far away southport is lol!!!
