Fiesta-Si.com • View topic - wheel bearing
 Post subject: wheel bearing
PostPosted: Fri Mar 04, 2011 10:40 pm
what is the sound when one is buggered?
grazie :thumbsup:
 Post subject: Re: wheel bearing
PostPosted: Fri Mar 04, 2011 10:51 pm
constant wheering noise
PostPosted: Fri Mar 04, 2011 11:00 pm
like a droneeee?
PostPosted: Fri Mar 04, 2011 11:49 pm
yeah when you turn a corner it gets louder.
PostPosted: Sat Mar 05, 2011 11:03 am
As above, I can hear mine but checked all wheels and they seem to be fine so I hope you have better luck lol.
PostPosted: Sat Mar 05, 2011 11:08 am
yeah groaning noise or grinding will be worse on corner if you can jack it up do that then check for play top to bottom and side to side put both hands on wheel and wiggle it
PostPosted: Sat Mar 05, 2011 12:09 pm
Yeah you can usually hear it. Do what 32couple said, also put your hand on the hub/strut or something connected to the wheel and give it a spin and listen to it while feeling for roughness. Normally the play gives it away depending how bad it is though.
Do you suspect front or back has gone?
PostPosted: Sun Mar 06, 2011 11:08 am
Well my dad said he heard it from the front! So il check them both on my next day off! Expensive job?
PostPosted: Sun Mar 06, 2011 11:17 am
At a garage yes but doing it yourself no, just tricky sometimes.
PostPosted: Sun Mar 06, 2011 12:08 pm
rear bearings are easy but front bearings need to be pressed in :thumbsup:
PostPosted: Sun Mar 06, 2011 2:31 pm
The bearing is about £35 then you'll have labour.
(Well a rear bearing for a ZS just to give you an idea)
PostPosted: Mon Mar 07, 2011 9:09 pm
Hmm, could I press it in myself with the right tool? Sounds pricey chris
PostPosted: Mon Mar 07, 2011 9:43 pm
Nah you need an actual press to do it, no other way to be fair.
PostPosted: Mon Mar 07, 2011 11:29 pm
I hate doing wheel bearings. If you want to save on labour, take the hub off the car, and take it with a wheel bearing to a garage and just get them to press it in while you wait. Take it home, put it all back together, jobs a good 'un!
PostPosted: Tue Mar 08, 2011 10:13 am
Hmm, sounds like a plan, however when i turn corners it's fine :s il have to check for play to get a proper diagnosis! Easy to take the hub apart?
PostPosted: Tue Mar 08, 2011 8:09 pm
Hubs aint toooooo hard to take apart to be fair, just nuts and bolts :)
PostPosted: Tue Mar 08, 2011 8:32 pm
Yeah not hard at all. Just look at what's attached, and take it all off. Hardest part is seperating it from the lower ball joint without damaging the rubber, but it's doable with a hammer and some leverage as opposed to a ball joint seperator.
So what's on there, er, brake calipers, brake discs, track rod, suspension, and seperate it from the ball joint. Not too hard at all...
PostPosted: Wed Mar 09, 2011 8:01 pm
Lmao! If there's play in the wheel I'll get it sorted, if not then sound!
