Fiesta-Si.com • View topic - Overheating HELP!!
 Post subject: Overheating HELP!!
PostPosted: Wed Feb 23, 2011 8:11 pm
Rite, i have a 1.4 zetec in my fiesta and it keeps overheating
Iv changed the temperature sensor and the water levels are rite
Also the pressure cap on the intercooler
The fan is cutting in at the rite point too
It still overheats!
Can anyone help?
Cheers :|
 Post subject: Re: Overheating HELP!!
PostPosted: Wed Feb 23, 2011 8:15 pm
What symptoms are you classing as overheating?
PostPosted: Wed Feb 23, 2011 8:22 pm
Temp gauge dial is going round to red
Some sort of boiling and spitting sound
A lot of steam from header tank
PostPosted: Wed Feb 23, 2011 11:12 pm
Try taking the cap off the header tank, then run the engine from cold, see any bubbling? If you're brave also squeeze some hoses and see if there's bubbling, could be a sign of an airlock. The radiator could also be blocked.
PostPosted: Thu Feb 24, 2011 7:30 pm
Get a new cap for the expansion tank too if that doesnt work ^^^
PostPosted: Thu Feb 24, 2011 10:46 pm
Will do cheers you lot!
I know that the intercooler pipe is stone cold so maybe there is some sort of blockage
:thumbsup:
PostPosted: Fri Feb 25, 2011 4:23 am
intercooler ? 1.4 zetec turbo ?
PostPosted: Fri Feb 25, 2011 7:24 am
if you got cold pipe sounds like a blockage have you checked in you oil filler cap for any gunk could be blown head gasket any steam smoke out of exhaust?
PostPosted: Fri Feb 25, 2011 6:54 pm
Check thermostat mate ;)
PostPosted: Fri Feb 25, 2011 9:48 pm
There is no gunk in the oil
Yeah a bit of smoking out of the exhaust but nothing other than normal
Thermostat has been checked too
:thumbsup: :|
PostPosted: Sat Feb 26, 2011 4:49 pm
If you can disconnect the pipe that is cold start the engine give it gentle revs and see if water cones out the pipe but becarefull an only try when engine is cold
PostPosted: Wed Mar 02, 2011 2:56 pm
Is the water cerculating? If not sounds like a fubar'd water pump,
PostPosted: Thu Mar 03, 2011 3:43 pm
probably cooked the headgasket now anyway is the water level going down?
