Fiesta-Si.com • View topic - Scary noise - please help
PostPosted: Mon Feb 14, 2011 1:27 am
Today my car has developed a scary scraping noise. It sounds like something dragging on the floor but I can't see anything on the floor and it also happens while im stationary. I checked my oil in fear and it was pretty low but I filled up to the max line and it's still making the noise. The warning lights didn't come on at all either.
I have been having trouble with my rear drum leaking brake fluid but I've been keeping it topped up until I can replace the piston. Could that be causing it? I am really worried that it's coming from inside the engine.
Other possibility I'm thinking is there is a squeak coming from a belt somewhere, could that cause a scraping noise?
As im at a big loss for this noise I'm gonna take it to the mechanics first thing so he can atleast have a listen but if any of you had an idea I may be able to sort it or atleast have a direction to point him in.
Cheers
PostPosted: Mon Feb 14, 2011 6:20 pm
is it a scrapping noise or a grinding noise poss tensioner goin faulty might be best if you could get a vid up so can hear it ui know its a long shot lol
PostPosted: Mon Feb 14, 2011 7:30 pm
if it makes to noise when stationary must be engine based, possible bearing going, belt tensioner, alternator or water pump
PostPosted: Tue Feb 15, 2011 2:40 am
its the cat dying :( oh well at least its not the engine. Steve (my mechanic) said it will get worse until i replace it, going from a rattle to the sound a tin can with 3 bolts being shaken about :lol:
thanks for the help guys
