Fiesta-Si.com • View topic - My M Reg SI Brakes go stiff and lights go dim.. any ideas?
It is currently Wed Mar 25, 2026 3:29 pm
PostPosted: Sun Feb 06, 2011 11:48 am
was the alternator new and has the stereo had the permant live wired up correctly :thumbsup:
PostPosted: Sun Feb 06, 2011 11:49 am
did it pass mot like this? could be earth wire draining battery ,could be servo faulty
PostPosted: Sun Feb 06, 2011 12:00 pm
Does sound like faulty servo, similar problem on my van.
PostPosted: Sun Feb 06, 2011 6:56 pm
Have you had your battery checked at all out of interest?
To be fair, sounds like the person who did the MOT is a tit if hes let a faulty servo pass the MOT. To check it, while the car is switched off, pump up the brake pedal until its nice and solid - about 5 pumps should do it, then hold your foot on the pedal and turn the engine on, the pedal should then go down. If it doesnt, its a clear indication of a faulty servo.
PostPosted: Sun Feb 06, 2011 8:28 pm
I would get a charge and drop text done on the battery. If either come back with bad results, change it... If that doesnt fix it, start looking at other things like ISCV :)
PostPosted: Sun Feb 06, 2011 8:38 pm
the brake problem wont be electrical, check the vaccuum hose that goes from the servo to the inlet manifold is connected properly and not damaged.
does the lights go dim when u brake wen the car is warmed up?
PostPosted: Sun Feb 06, 2011 10:19 pm
Like I said, check the ISCV :)
PostPosted: Tue Feb 08, 2011 7:46 pm
servo sounds to blame to me
Users browsing this forum: Google [Bot] and 97 guests
