Fiesta-Si.com • View topic - Flywheel refitment
It is currently Wed Mar 25, 2026 3:30 pm
 Post subject: Flywheel refitment
PostPosted: Fri Jan 14, 2011 1:55 am
Just another quickie as im learning :P
I believe the Cylinder 1 has to be TDC when refitting the flywheel and the flywheel will only go on one way
How do i identify the TDC mark on the flywheel? Dont want to knacker the engine before i start :doh: :lol:
 Post subject: Re: Flywheel refitment
PostPosted: Fri Jan 14, 2011 2:05 am
Why does it have to be at TDC? If the flywheel only goes on one way - which is does, just stick it on and line it up to tdc on the crank :)
PostPosted: Fri Jan 14, 2011 6:42 pm
Make sure that no.1 cylinder is on TDC when ya time her up and the cams are locked in. Then shell be all timed up as the flywheel will go on one way only.
PostPosted: Mon Jan 17, 2011 3:01 pm
only fits one way mate, theres 6 holes for the bolts to go through and 1 smaller hole which fit onto a dowl on the crankshaft face, hope this helps
Users browsing this forum: Google [Bot] and 97 guests
