†Ûi³ÿßrȬþ;
ob_start();
†Ûi³ÿßrȬþ;
ob_start();
[phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1056: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4769: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4770: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4771: Cannot modify header information - headers already sent by (output started at [ROOT]/config.php:19)
hi i have a 2.0 silvertop fiesta mk5 i had trouble wiring it in but have done it now but now when a start it it will run for 2-3 secs and then cut out any ideas plz thanks
It's a good sign if It will at least start, when It runs does it run ok and Not miss firing and lumpy, if It runs ok For the 2 seconds then I would look at fuel supply like is fuel pump running ok when started as ecu looks For a run signal to keep pump running other thing is fuel pressure
Joined: Thu Mar 30, 2006 1:23 pm Posts: 11348 Location: Lincoln
Thats got to be a fueling issue, as Will said, check the fuel pump is running still, and down to fuel pressure.. I know it sounds silly but my mates 1.8 did that once, and it was the fuel filter!
_________________ Daily isn't so Special. And it makes me sad. Need space and time and I'll crack on with Jams si!
