Fiesta-Si.com • View topic - merhhhh. bad day.
It is currently Wed Mar 25, 2026 8:38 pm
 Post subject: merhhhh. bad day.
PostPosted: Tue Dec 21, 2010 4:50 am
after having my exhaust fall off the day before, i decided to go get it replaced.
after starting the engine, there's a huge sqweel like the driver belt was slipping, but it wasn't slipping, the whole thing wasn't even spinning!
smoke was coming out of the bottom of it where the main cog spins the belt? *correct if im wrong*
I did leave it for a good day and a bit before starting again, what with the REALLY cold weather and all.
But, i think it's seized?
Cause, it couldn't of frozen stiff, no?
Haha. Aint no lying either! :D
 Post subject: Re: merhhhh. bad day.
PostPosted: Tue Dec 21, 2010 2:03 pm
It sounds like it may have frozen in place, scary stuff.
PostPosted: Tue Dec 21, 2010 2:46 pm
Can that actually happen though? =/
I'ma try it shortly. Gotta get to work soon.
otherwise it's a 3 mile walk :(
PostPosted: Tue Dec 21, 2010 2:49 pm
Does your coolant actually have coolant in it? If it's just water it will freeze, expand and possibly crack blocks, heads, pipes, etc
What is it doing exactly when you try and start the car?
PostPosted: Tue Dec 21, 2010 2:56 pm
The car starts, it runs, but with a huge sqweeling noise coming from the driver belt, cause it's not spinning.
That's all I can explain really.
It's so loud, my mum ran away from the car :P
PostPosted: Tue Dec 21, 2010 2:57 pm
I've only had the car a month or so, so probably doesn't have any antifreeze or anything =/
PostPosted: Wed Dec 22, 2010 3:11 am
If the coolant froze on a zetec, really strong chance the fanbelt would slip off seeing as the water pump is run by the alternator/fan belt, remove the fan belt and start it again
PostPosted: Thu Dec 23, 2010 1:45 am
Okay. All is well :(
It just froze over for a while.
Exhaust sorted too :)
