Fiesta-Si.com • View topic - help needed urgently
It is currently Fri Mar 13, 2026 10:42 am
 Post subject: help needed urgently
PostPosted: Sun Dec 05, 2010 5:30 pm
my timing belt tensioner blew up today. the car cut out straight away so im hopeing there will be any other damage valves etc. has anyone had this happen to them before and if so what damage was done.
also how easy is changing the belt etc on a 1.6 Si
 Post subject: Re: help needed urgently
PostPosted: Sun Dec 05, 2010 5:49 pm
i guess you need to get a haynes manual on changing the cam belt then you need to put a new cam belt kit on if the head turns with hitting any thing i would also take spark plugs out if thats ok then a compression test the engine but if its low on any of the 4 cylinder then its another head or a engine ...
PostPosted: Sun Dec 05, 2010 6:06 pm
s said above, its not that bad a job but need to follow a manual and its quite restricted access, be carefull when turning it over to aline the cams so not to cause any more damage and with the plugs out should be easier to feel any contact, its a pain but only way really is to put belt kit on and do compression test, if there has been and contact will bend a valve which wont seal and compression will be down on offending cylinder, if so its a head of job. If only a pair of valves (not pistons) not that bad to just replace those ones
PostPosted: Sun Dec 05, 2010 6:10 pm
Thats the plan so far. But not alot of space to do it
PostPosted: Tue Dec 07, 2010 11:26 am
chances are you will need atleast 6 new valves, but get a cambelt kit first (about £40 depending on where you buy it from), fit that, then turn it over by hand first with the spark plugs out, theres a small chance you haven't damaged anything, but you are most likely going to need the head off, have new valves fitted and lapped in, then a pressure test on the head after from a engineers, or fit a 2nd hand head (i would recommend you repair the old head for peace of mind), you will also need a head gasket set and head bolts if the head does have to come off
PostPosted: Tue Dec 07, 2010 7:50 pm
going to try set timing and turn engine over by hand to see if there is any noticable damage.
but as a back up plan ordered another engine for £225 delivered with box and started etc.
PostPosted: Wed Dec 08, 2010 9:49 am
do you know what the timing marks are?
PostPosted: Wed Dec 08, 2010 12:31 pm
i have some info from my work. there is notches in crank pulley to line up with sump.
also cams have groove to set them
PostPosted: Wed Dec 08, 2010 3:33 pm
yup thats pretty much it, theres a couple grooves in the the crank pully, one of them lines up at 1 o'clock on the sump, and remove the cam cover and use a locking bar to set the cams, if the cams don't line up rotate the crank once more
PostPosted: Wed Dec 08, 2010 4:30 pm
yea that it. only problem is my drive is under 2 foot of snow.
so shovel out before i start again
PostPosted: Thu Dec 09, 2010 8:17 am
set the cams and crank to both TDC built it back up and turned it by hand. no sign of anything hitting or getting in way of pistons. so connected battery back up etc now it wont start, it is sparking but not sure if sparking at right time. so im thinking i need to rotate the crank another 360 degrees.
PostPosted: Thu Dec 09, 2010 3:16 pm
Compression test, also get a spark tester, or a screw driver
PostPosted: Thu Dec 09, 2010 4:58 pm
i got my comp tester out but none of the threads were the sames as the plug so borrowing one from a mechanic at the work. just keeping fingers crossed now though
PostPosted: Thu Dec 16, 2010 4:35 pm
just had engine arrive. hoping to get it fitted tonight if all goes well
PostPosted: Thu Dec 16, 2010 4:44 pm
did you find out what damage was done to your last engine?
PostPosted: Thu Dec 16, 2010 5:36 pm
yea 8 valves bent so no compression
Users browsing this forum: Majestic-12 [Bot] and 51 guests
