Fiesta-Si.com • View topic - how long before your heaters in your fiestas are hot
It is currently Wed Mar 25, 2026 3:29 pm
PostPosted: Tue Nov 16, 2010 6:13 pm
as above, how long does it take for your mk3 fiesta heaters to blow out hot air?, ive back flushed my matrix and its still not great unless its been idling over for half hour before i drive it, so im temped to get a new matrix unless your answers come back similar to mine, cheers
PostPosted: Tue Nov 16, 2010 8:34 pm
should heat up as quick as the engine, how long does the temperature gauge take to rise? could be thermostat stuck open, are the pipes geting hot feeding the matrix hence no air locks?
finally if engine temperature rises normally but not heater are the heater controls working ok? eg the flap letting air from the matrix?
PostPosted: Tue Nov 16, 2010 9:02 pm
how hot does your one take to get hot or doesnt it?
PostPosted: Tue Nov 16, 2010 9:08 pm
"warm"air in two/3 mins.
"hot" 5/10 mins driving.longer ticking over.
PostPosted: Wed Nov 17, 2010 1:04 am
id say your thermostats gone mate
PostPosted: Wed Nov 17, 2010 1:07 am
After a 15min journey it will get warm, if i have the blowers on to clear the screen it will take even longer, but if i leave it ticking over before a journey for 10/15mins then put the blowers on, they will blow out hot air for about a min then go back to being warm again, ive checked the water pipes off the rad and they get red hot, and i know for certain its not air locked, i'll change the thermostat for a new one, clean out the housing and reverse flush the matrix 2moro evening and hopefully i should have some hot air for once, cheers guys
PostPosted: Wed Nov 17, 2010 1:09 am
Ie just changed the thermostat on mine and thats about the same times for mine to heat up too!!!!
PostPosted: Wed Nov 17, 2010 1:10 am
Oh, and its definatly not the controls or the flap not working as i removed them about 5 weeks ago to fix a waterleak in the baulkhead snd i inspected it all then
PostPosted: Wed Nov 17, 2010 1:12 am
im sure thats about right for old car, not like modern day wonders that seem to have instant heat but look at how much more advanced the systems are!!
PostPosted: Wed Nov 17, 2010 1:13 am
Hmm, i'll do it anyway as its dirt cheap for a thermostat, i used to havd a 1.1 and a 1.3 and there heaters would blow out red hot air all the time no matter what, thats basically what im aiming for now
PostPosted: Wed Nov 17, 2010 1:20 am
yea cant hurt to change it,seeing as your in there anyway. 8-)
PostPosted: Wed Nov 17, 2010 10:50 am
cheers for your help guys, last question now, which way does the water circulate through the matrix? from the thermostat housing to the matrix then to the T piece off the expansion tank, or from the T piece to the matrix to the thermostat?
PostPosted: Wed Nov 17, 2010 10:57 am
Mines only takes a few minutes if that, pretty good heater.
PostPosted: Wed Nov 17, 2010 11:29 am
when you put the fan on the windscreen (to reduce the condensation), and close the normal ones. is it normally that it doesnt throw a lot of air ?
PostPosted: Wed Nov 17, 2010 2:01 pm
PostPosted: Wed Nov 17, 2010 3:26 pm
PostPosted: Wed Nov 17, 2010 5:20 pm
mine runs luke warm too
and sounds like someone blowing a trumpet :doh:
so cant use it at the mo, noise seems to be coming from
heater motor under the bonnet, anybody else had this happen?????
it driving me mad :banghead: :banghead:
PostPosted: Wed Nov 17, 2010 5:21 pm
mole not got his one off yet? :hmm:
PostPosted: Wed Nov 17, 2010 5:34 pm
Users browsing this forum: Google [Bot] and 97 guests
