Fiesta-Si.com • View topic - Front Shocks
It is currently Wed Mar 25, 2026 3:26 pm
 Post subject: Front Shocks
PostPosted: Fri Nov 05, 2010 11:29 pm
Hi i have a problem with some front shocks i got off here my own fualt :) not shure if i can get a round this by fitting xr2i or nomal mk 3 hubs
The shocks i have the dia of the hub hole is bigger then the socks it moves a round and not a nice fit they are spexs
 Post subject: Re: Front Shocks
PostPosted: Sat Nov 06, 2010 9:03 am
i belive its been mentioned on here before about the possibility of shimming the shock to make it a better fit but not tried it, apart from that options are changing hubs or getting right shocks that fit
PostPosted: Sun Nov 07, 2010 7:02 am
PostPosted: Sun Nov 07, 2010 10:37 am
I know 3.5 shafts are different to mk 3 so may need changing.
PostPosted: Mon Nov 08, 2010 3:52 pm
Yeah basically the whole front end is slightly different between the 3 and 3.5.
PostPosted: Mon Nov 08, 2010 8:33 pm
yes i may just sell the shocks and springs now they are painted with new dust gators
PostPosted: Tue Nov 09, 2010 1:20 pm
best thing to do is fit the shocks and springs meant for you car/engine, as the mk3 shocks have a smaller diameter leg, so to fit mk3 shocks on to a mk3.5, you will need the shocks, hubs, driveshafts and either ball joints to match, there are about 5 different types of ball joint (tapered cone, staright cone, staggered cone, the the angle of the joint for non p/s models and p/s models)
ive got a k reg mk3 1.4 cvh, which i fitted mk3.5 shocks/ hubs/ driveshafts/ and ball joints, i had to use ball joints from a 1.8xr2i/puma, its ok to do it this way but when yopu swap mk3.5 stuff for the mk3 stuff its not as firm becuase the mk3's had lighter/less powerful engines
hope this helps
PostPosted: Tue Nov 09, 2010 9:35 pm
yes i decided to sell them i had new ford shocks on the back 3 years ago that have only done 2000 miles and a new set from ford for the front is only 120 pounds so i be doing that now ..
PostPosted: Tue Nov 09, 2010 9:55 pm
you can shim them out
i did it with a set of mk3 avo's in to a si hub
iirc you need a 0.6mm thick shim
PostPosted: Wed Nov 10, 2010 4:29 pm
Yea, shimming works perfectly!
Users browsing this forum: No registered users and 95 guests
