Fiesta-Si.com • View topic - Random cable in my loom, rev counter??
It is currently Wed Mar 25, 2026 4:49 pm
PostPosted: Tue Oct 12, 2010 11:27 am
i've got a mk3 fiesta 1.4 freestyle on the weber carb and it uses the distributorless ignition system, and ive fitted a dash clocks with the rev counter to wire in as the base models never came with them
ive taken my dashboard out to cure an on going water leak, whilst doing so i thought i would tidy up the loom behind then dash.
problem is, all the plugs are connected and there is 3 wires that go into 2 pins on a plug near the steering collomn which doesn't connect to any thing, the wires are
brown - in its own pin in the plug - earth obviously
brown/yellow
brown/green - these both share the second pin
ive followed the cables and the brown/green wire goes to pin 1 on the dash clocks, which looks to be the rev counter
the brown/green wire goes into the engine bay and im assuming it goes to the ignition system somewhere
does anyone know for sure what the cable is?? and what i would need to plug in to it to get the rev counter working?
any help would be very much appreciated
cheers, tony
PostPosted: Tue Oct 12, 2010 5:34 pm
a pucture would be usefull :D
PostPosted: Sat Oct 23, 2010 11:57 am
found out what it does, it plugs into the choke cable and turns the dash light on if my car were to have a choke
PostPosted: Sat Oct 23, 2010 5:32 pm
What ignition system are you using to run the carb with coil pack. Im Guessing a ford ESC unit or simular?
PostPosted: Tue Oct 26, 2010 12:29 am
Yeah, either the esc or edis unit, standard with the car from new
PostPosted: Tue Oct 26, 2010 12:31 am
PostPosted: Tue Oct 26, 2010 2:34 pm
If its Esc you need the red and green wire to the rev counter
Edis will be pin 11, there might not be a wire in it though so you need to drill through and use a wire and connector from a scrap loom to push through.
Same with the plug for the clocks, doubt you will have a cable for the rev counter so you will prob need to add one in
