Fiesta-Si.com • View topic - 2.0 maf
It is currently Wed Mar 25, 2026 7:31 pm
 Post subject: 2.0 maf
PostPosted: Sat Oct 02, 2010 10:26 pm
how do you connect a 2l maf to the original si pipework? tried warming the pipe up and stretching it, but its way to big to stretch.
 Post subject: Re: 2.0 maf
PostPosted: Sun Oct 03, 2010 8:26 pm
Onto a 1.6? You do know it gives the wrong readings right? It's better to just leave it unplugged.
PostPosted: Mon Oct 04, 2010 10:03 am
Sorry i meant mass air flow (the one connected to the air filter)
are you thinking of the MAP sensor?
PostPosted: Mon Oct 04, 2010 10:48 am
A 2.0 maf gives readings intended for a 2.0 ecu. A 1.6 ecu is looking for the readings from a 1.6 maf.
PostPosted: Mon Oct 04, 2010 10:36 pm
you can fit the insides of a 1.6 one into a 2.0 maf i think. then the ecu will read it correctly and there will be less restriction of the air
To rebuild?
PostPosted: Mon Oct 04, 2010 10:53 pm
This guy is trying to put a 2.0 maf on a 1.6 standard intake, won't fit, unless he gets [hidden].
PostPosted: Mon Oct 04, 2010 11:23 pm
i guess you would have to use rs 1800 pipe work if it wont strech far enough
To rebuild?
