Fiesta-Si.com • View topic - clutch pedal
It is currently Wed Mar 25, 2026 5:02 pm
 Post subject: clutch pedal
PostPosted: Fri Aug 13, 2010 3:01 pm
mine has stared to make sounds to me when ever you put it down is there any way off geting rid off it.
cheers rob
 Post subject: Re: clutch pedal
PostPosted: Fri Aug 13, 2010 3:20 pm
isnt that usually cause by the thrust bearing? dont hold me to it cause i dont have a clue lol
PostPosted: Fri Aug 13, 2010 5:17 pm
the pedal bushes can make a squeeking noise sometimes
PostPosted: Fri Aug 13, 2010 5:32 pm
ow cheers any way to stop it lol
PostPosted: Fri Aug 13, 2010 5:34 pm
is it a squeak when you depress the pedal even with the engine not running? if so may be a spray with silicon spray or something
PostPosted: Fri Aug 13, 2010 6:48 pm
yh you got it right it squeaks with and with out it runing
PostPosted: Wed Sep 01, 2010 7:25 pm
mine used to do this, then the ratchet and pawl mechanism collapsed and snapped a new clutch cable on the biggest roundabout in Plymouth, try spray grease first, if it goes away then comes back, replace the ratchet and pawl
PostPosted: Wed Sep 01, 2010 7:26 pm
ow cheers
