Fiesta-Si.com • View topic - just ordered a strut brace but how easy to fit r they?
PostPosted: Thu Jan 05, 2006 4:55 pm
i have just orded a polished sparco strut brace (xr2i 16v/ rs1800) for si 2 improve handling and add some more bling 2 the engine bay but does ne1 know how easy they r 2 fit and if anthing in the engine bay would need 2 b relocated? :look:
cheers
PostPosted: Thu Jan 05, 2006 5:29 pm
Nothing needs to be relocated, and as long as you can use a drill then you'll be fine. You will need to move the coolant header tank however, as it gets in the way of one of the bolts when you are fitting the strut brace. Ideally take it off completely, but I managed to fit mine without taking it off, and just unclipping it and pushing it aside when fitting the strut brace.
You *might* need to remove the Ford jack aswell, just to make it easier to fit, cant remember if I did. But it can all go back in place once fitted :)
PostPosted: Thu Jan 05, 2006 5:34 pm
Just for reference and to have a gander, that's what it should look like :)
PostPosted: Thu Jan 05, 2006 6:29 pm
PostPosted: Fri Jan 06, 2006 9:27 am
PostPosted: Fri Jan 06, 2006 12:23 pm
PostPosted: Fri Jan 06, 2006 12:26 pm
