Fiesta-Si.com • View topic - Is this common?
 Post subject: Is this common?
PostPosted: Wed Aug 04, 2010 1:02 pm
My heater control, one day decided to not work on 1, but still did on 2+3
So i thought ok fair enough, and then it worked again.
But recently it stopped working on 1 all together, so i got another one from the scrappy
And it's the same!
D'ya recon it's the wiring or relay or something, or maybe it's just a common problem with the switch?
 Post subject: Re: Is this common?
PostPosted: Wed Aug 04, 2010 2:08 pm
I am guessing there is a dodgy relay, but I could be wrong.
PostPosted: Wed Aug 04, 2010 3:42 pm
im guessing switch mate:)
PostPosted: Wed Aug 04, 2010 10:00 pm
id guess both lol
had to sorry
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Thu Aug 05, 2010 12:02 am
neither, its the flux capasitor* thats failed.. lol
PostPosted: Thu Aug 05, 2010 12:13 am
try the relay or fuse for the heater blower. Could be a burnt out connection.
PostPosted: Thu Aug 05, 2010 6:34 am
if its the fuse it wont work at all, i doubt its the relay. try and check the wiring maybe there is a loose connection, if not try replacing the switch.
PostPosted: Sat Aug 07, 2010 9:22 am
not so common on mk3 fiestas but on focus mondeo transits,
there is a resistor near the blower motor which causes this problem.
the wireing gets too hot and melts aswell ford have made a modified wire aswell as resistor.
best bet is the scrappys as the ford one is £55+VAT, and all mk3s less aircon are the same
