Fiesta-Si.com • View topic - sill info
It is currently Wed Mar 25, 2026 8:38 pm
 Post subject: sill info
PostPosted: Thu Jul 01, 2010 10:29 pm
hi all does any one know how hard it ir to put a new cill on my 5door
and can i just use a mig welder
thanks rob
 Post subject: Re: sill info
PostPosted: Thu Jul 01, 2010 11:50 pm
it depends how bad (rusty) the part is behind it to weld it to. dont think is to bad pretty sure its straight forward. just cut out old part and weld on new one,
PostPosted: Fri Jul 02, 2010 5:20 am
your some times better to get a full sill.. when i put a sill on i put the sill over it then i mark the old sill by scratching with a nail then i know were to cut the old sill off also as the sill was spot welded on i get a spot weld remove bit ...
when i put the new sill on i make shure it fits and then i take the old paint of also i drill the new sill with 6mm holes long the bottom edge about 25mm space between each and also on the top edge then when the sill is ready to weld i nomal weld though the holes and makes it look like a spot weld ..then mig the rest up
P.S only drill the new sill
PostPosted: Fri Jul 02, 2010 1:41 pm
i am getting a cover thing there is a big hole by the drivers door and by the back
so i have to drill it the plug thing it with the mig yh ?
cheers rob
