Fiesta-Si.com • View topic - What is this wire?
It is currently Wed Mar 11, 2026 11:52 pm
 Post subject: What is this wire?
PostPosted: Sat Jun 26, 2010 10:35 pm
So I was under the car today and found this wire unplugged. No idea what its for but the plug definitely belonged in that socket 100%
This is as you lay under the car by the licence plate. Its the wire plugged in at the top of the picture. By the wet hand print
What does it do as its been unplugged for a while by the looks of it.
 Post subject: Re: What is this wire?
PostPosted: Sun Jun 27, 2010 9:51 am
it goes into the gearbox ... so? erm reverse light switch .. or transmission oil light ? dont quote me tho
PostPosted: Sun Jun 27, 2010 10:38 am
hmm well if I now have a reverse light then it must be that. If it isn't then the reverse light will still be off.
Won't know if its the transmission oil light until I get a warning if I ever let it get low enough :)
PostPosted: Sun Jun 27, 2010 11:45 am
reverse light switch. its the only one on a BC gearbox. low oil level :lol: the tight sods never put a drain bung in it so you could change it easily why would they tell you when its empty :D
Jam
PostPosted: Mon Jun 28, 2010 12:59 am
Yep was the reverse light. I actually went YES! something got fixed, when matt said I had a reverse light :lol:
PostPosted: Fri Jul 02, 2010 8:28 pm
just spotted your missing a metal bracket that bolts to the gearbox where the starter motor bolts to :insanity:
PostPosted: Mon Jul 05, 2010 12:18 am
Am I?
Could be why the starter motor was loose on saturday and had to be tightened up :red:
Friggin car...
