Fiesta-Si.com • View topic - possible ball joint?
It is currently Wed Mar 25, 2026 8:43 pm
 Post subject: possible ball joint?
PostPosted: Sat Jun 19, 2010 12:12 am
right for a while now ive had a bit of a "clunk" in the steering when going left. after doing quite a bit of driving it gradually got worse and now it seems to sort of stick instead of going back straight if you catch my drift also makes some nasty creaky noises lol was thinking the ball joint? also heard something about uj?
any help would be appreciated :)
The Fat Fake Xr2i
 Post subject: Re: possible ball joint?
PostPosted: Sat Jun 19, 2010 12:23 am
1.1 I take it?
Yes get the Universal Joint checked.
I had an identical problem in my old 1.1. Wouldn't correct the steering after turning. Felt like I was turning a bus and not a fiesta. Lots of noise coming from it as it gradually seizes up.
quick fix £50 rebuild on it at a garage and that sorted it.
Sadly mine got written off shortly after that so can't say how long the rebuild lasts but the person who I gave it to tells me it is still going strong :thumbsup:
I miss that car it had no rust at all and was almost 18 :frown:
PostPosted: Sat Jun 19, 2010 5:10 am
could be ball joint also i had to do the top mounts were bad and the stud mount bearing too will need spring compressor tool i got mine for 15 pounds from screw fix
The problem also you need to do both sides as well
PostPosted: Sat Jun 19, 2010 10:35 am
my vans ball joint is gone and that is creakin like fook
