Fiesta-Si.com • View topic - WTF is this doing here
 Post subject: WTF is this doing here
PostPosted: Wed May 26, 2010 10:09 pm
ok so my problems on the Rs are as follows, ignition lights stays on, rear sidelights stay on when engine is turned off and key is taken out :( fan doesnt kick in when car gets to temp, no interior light, no interior clock.
now i have this yellow relay under my bonnet or did have till my mate disconnected it, everything seemed to be fine till he did that, now i aint the foggies how it goes, it had thermo, fan ignition and battery connected to it, any ideas, pic enclosed
PostPosted: Wed May 26, 2010 10:19 pm
Make sure the connections on that relay arent nackered, check the wires. Check the relay.
Make sure all your earths are okay, as that could cause it.
PostPosted: Wed May 26, 2010 10:21 pm
i dont actually have it connected any more, i was wondering do you know which wires connect to which pins on the relay ??
PostPosted: Wed May 26, 2010 10:26 pm
Wouldnt know personally as I have only had experience with zetecs in a fiesta...
Best of asking on fiesta turbo . com
Also get a proper relay holder, or at least bolt it up, it looks rough having it laying like that
Why did you disconnect it???
PostPosted: Wed May 26, 2010 10:34 pm
it wasnt actually me that disconnected it, i have posted but as im not in with them i doubt i will get a responce, yeah once i have everything working i will :)
PostPosted: Wed May 26, 2010 11:43 pm
Ive never seen any relays in that area before, I know there is nothing like that on mine so its possibly something thats been added on at a later stage....
PostPosted: Wed May 26, 2010 11:45 pm
it works the fan and apparently rear lights :(
PostPosted: Wed May 26, 2010 11:48 pm
ok sorry to double post, i think ive found the problem, it is set up to always run the fan and thermo, how do i take the wiring back to standard ?
PostPosted: Wed May 26, 2010 11:50 pm
I would worry more about why somebody set it to do that.
PostPosted: Thu May 27, 2010 12:04 am
cause its running a t3 well i belive so anyway :(
PostPosted: Thu May 27, 2010 12:30 am
shouldnt make any difference mate, im running the same but i dont have random relays running different things like that!!
PostPosted: Fri May 28, 2010 12:53 am
wierd, ok ive put it down to a faulty fan switch, how does your wiring go, ?? ive tried combo's all day :(
PostPosted: Fri May 28, 2010 7:48 am
looks like a case of butchered wiring :(
is the engine ok?
PostPosted: Fri May 28, 2010 8:38 am
yeah engine starts fine and ive corrected every other problem, just can't get the fan to come on with the fan switch, only way i can get it to work is if i run it off the ignition, which i dont really want to do as it puts a strain on the alternator and tbh sounds shit, will most likely end up going down the fitting a manual over ride switch inside the cabin and will just have to remember to keep an eye on the temp gauge.
PostPosted: Fri May 28, 2010 11:16 am
